Still furry. I'd better check. Having also some issues choosing first gear when bike is cold.
In iron Lambretta cylinders we trust!
I always set the rear as low as it will go with the thinnest shim I then lap the front drive sprocket sleeve down to suit yes its time consuming but so is a strip downkejj wrote:I understand alignment was made to the front sprocket and thus required a larger shim. Still this large shim should have triggered off an alarm.
While looking at the front sprocket I found this movement. Don't remember it to be this flex in my other rebuilds. Crank bearings gone wrong.
https://youtu.be/ZmXCrzxdxCY
