Inlet manifold
rainbowrunner
Main scooter: Series 2, RT 195
Fitted rt 195 kit on series 2. The manifold makes the 25mm carb point to the left slightly as in pic. Manifold was from MB. Is there any other that could make the carb straighter Image
Sent from my GT-S7275R using Tapatalk
philcasino1973
Main scooter: lambretta gp200
i have exactly same on mine .... when i put panel on [italian gp] its flattening the elbow rubber looks very restrictive and very rich running
wil be interested to see any comments on this as really wanted to run thro airbox its a 25 dellorto
phil
rainbowrunner
only done 150 mile on it so far, runs fantastic, the air hose rubber is tightened to an inch of its life because it kept slipping off at the elbow, gona give readspead a bell in morn, been told they do a manifold that could straighten the carb up a bit.
philcasino1973
will be interested to see outcome of this ...see you are in wigan m8 ....am only down road in haydock from bryn originally
regards
phil
Ilango
Main scooter: SIL Vijai Super
rainbowrunner wrote:The manifold makes the 25mm carb point to the left slightly as in pic.
Hi Rainbowrunner, I dont see any harm with this setup. Indian Vijai Super Mark 2 came with a Mikini licensed VM22 carburetor (in the name of Micarb) which also is slightly offset to the left (very much like in your scooter).
The VM has a broader float bowl that fouls with the engine mount boss and hence it doesn't fit straight on a Li (Dellorto) or GP (Jetex) manifold. However the air hose was the same for Jetex and Micarb setups.
If the air flow is restrictive with the side panels closed, here is an easy fix for the spigot type carb mounting.
Hold the manifold by the spigot side on a lathe and lengthen the spigot as much as possible without cutting into the bend and sacrificing its strength. Once done, shop it off keeping only as much length needed for your carburetor spigot.
Hope this helps.
Here are some pictures of my scooter. Not sure if you need to be registered user to view the pictures.
http://www.team-bhp.com/forum/vbpicgall ... iew&g=2517
-Ilango
    Users browsing this forum: Baidu [Spider], Google [Bot], Semrush [Bot] and 39 guests
