Burnt out Clutch
philtrate
Main scooter: LAMBRETTA GP RB225
thebassmasta wrote:I did exactly the same thing dude on the way home from brid, obviously the wind was a major factor, she gave up on me 22 miles from home. I was thinking about a readspeed 6 plate but people are telling me just to put a 5 plate in, Im reading all the posts regarding clutches and still havent made my mind up. CONFUSED DOT COM. It all boils down to budget, others im considering , SSC/Morris 5 plate, around £180 but not seen much info on them, MB 6 plate, looks good but its well over £400, woudnt touch the AF cassette type road version, you need arms like popeye to pull it in, but the race version is supposed to be better, Just need a very good clutch to handle a 24bhp imola
I've got the AF road cassette clutch in my RB it's so light and easy to use and I'm no popeye
lozmondo
AF road clutch in a 30 bhp monza, properly routed nylon lined cable, lovely
thebassmasta
Main scooter: GP TS1 240
what oil you using? in your af clutches? i was only going on experiance with my mates jet200, i would like to think that hes routed it badly cos they do look a nice bit of kit and affordable
roadrunnerian
i have an af road clutch in my ts1 i run with standard gear oil although some people use a lighter oil, my clutch is very light nylon cable and dog leg lever a top clutch m8
mickdale
andy francis website says af cassette clutch road "new version"
is there a modified/updated/better version to the older ones available?
if so are they more reliable/better?
Norrie Bodge
Sorry to revive this old thread!! But?
Which clutch is it that one recommends then for higher BHP lambrettas ?
My TS-1 230 with 6plates & atomic deep spider/pressure plate & std crownwheel notched for the 1st cork is slipping bigtime at 50+ :-(
Was fine b4 I altered my drive sprocket from 19 to 20 ??
All replies appreciated
Norrie Bodge
Few options?
Obviously prices vary? But which is best to go for?
Also regarding getting replacement parts too??
http://www.riminilambrettacentre.com/en ... a-46z.html
https://www.lambretta-teile.de/7-plate- ... etta-GP-dl
http://www.afrayspeed.co.uk/index.php?p ... tributeID=
Lambretta Sash
Main scooter: Lambretta TV 230
What do you call high hp?
Af cassette is not my choice, lth is good as is bgm one as I've recently fitted to avanti sprinter .
You can run st 4plate with right springs and prob get 2 years out of it as fond on our Rt @ 27hp motor.
Norrie Bodge
High HP is IMO TS1 RB20 220 250 etc etc m8
Norrie Bodge wrote:...............Was fine b4 I altered my drive sprocket from 19 to 20 ??
Are you sure it isn't the front cush drive slipping? wouldn't be the first time some miss-assembly has caused this.
