Electrickery ....no lights.
Timbo
GP225 12v electric ignition SIP speedo....fired it up a couple of times today and the lights and Sip speedo don't work. Horn does, and festoon bulb...but nothing else, checked earths and for loose connections but can't see anything....ignition switch?
Timbo wrote:GP225 12v electric ignition SIP speedo....fired it up a couple of times today and the lights and Sip speedo don't work. Horn does, and festoon bulb...but nothing else, checked earths and for loose connections but can't see anything....ignition switch?
I'd check all the connections on the junction block on the back of the headlamp before changing the switch
Timbo
They look ok...shall I take each one out and put back...?
Timbo
Loose wire in the black junction box at the back of the scoot....found by Ian at Hemel Scooter Services. Top fella.. 8-)
