Front hub rebuild.
kejj
Looking for pictures of a front wheel hub rebuild.
Last time I took it apart and reassembled it the 2 half nuts locked the brake/drive nav hub so it wouldn't move but instead stuck with the wheel moving with it.
The time before when I did the exact same job I could tighten the half nuts up quite good and the brake/drive part moved freely.
I am probably missing something important here but lack the knowledge of what it could be.
______________
Drum hub!!
________________________
http://tv175.wordpress.com/
Knowledge
A drum hub, not disc?
Martin
kejj
Knowledge wrote:A drum hub, not disc?
DRUM HUB!
AUSSIE
I think the main thing is to get all the distance pieces in the right order. Indian and italian are slightly different, indian ones have a spacer that fits through the oil seal and a washer on the outside, with the italian ones the spacer and washer is one component. If all correct the half nuts can be done up tight.
Sorry I cant find a picture of what I'm going on about :oops:
kejj
If someone do have a pic please post.
I tried looking at Stickys but it didn't get any clearer.
    Users browsing this forum: Ahrefs [Bot] and 9 guests
