GT Kit Jetting
Anyone else using GT186, Delly 25 PHBL and AF Clubman?
What jetting, needle and clip setting do you have?
goldeneye
Rob Miller using this set up on his TV2 . and it goes reet good. i"ll give him a buzz. ;)
goldeneye wrote:Rob Miller using this set up on his TV2 . and it goes reet good. i"ll give him a buzz. ;)
That would be helpful, thanks ;)
cezeta
isnt it covered in the instructions on this kit?
cezeta wrote:isnt it covered in the instructions on this kit?
Only says main jet 93-97, but I was wondering what others were using as all motors differ and I'm on the botton clip D22 needle with AQ266 atomiser and 100 main, yet it's still lean when cruising.
J1MS
Try a bigger needle jet a 268 should be better
Thanks J1MS, I understand that, ;) I was just curious as to what others had settled on.
cezeta
any idea of the power output of these kits? i have one for one of my servetas.
Diablo
Done right they can make 17hp on our dyno with a JL3
Diablo wrote:Done right they can make 17hp on our dyno with a JL3
What's that Al, 206cc?
Are you still running yours?
