Sometimes domed nuts and thin washers leave a bit of play
Tiny wheel wobble.......
Without wishing to sound rude have you checkd you nuts wheel nuts that is
bristolmod
- Main scooter: Lambretta TV175 S3- what else!
- Location: Bali-Hai bar, Locarno Ballroom Bristol, 1967!- mines a Brown Split!!
agree with Dennis- if there isn't a tiny bit of play I would be worried on hot days..........
Scootering since 1968.
alanscottj
- Main scooter: Lambretta GP SS250 Casa
Thanks all, I'll just keep an eye on it, see if it stays the same, if it gets worse I'll take another look
Lambretta Series 2 Rat - RB260, SuperTourer, Cyclone 5 gearbox ๐๐
- garry inglis
- Main scooter: ts1 230 and rb200
i had the same wobble changed everything but the layshaft bearing track on endplate after the tenth time stripping down i put in a new track put back together no wobble i actually measured the inside off both tracks and it a couple of thousand but over the length of layshaft it was a wobble
- garry inglis
buy the way scooter restorations sells both italian and spanish bearing tracks
alanscottj
Could you feel any movement on the shaft when you took the wheel off? I can't feel any movement at all, the layshaft feels solid?garry inglis wrote:i had the same wobble changed everything but the layshaft bearing track on endplate after the tenth time stripping down i put in a new track put back together no wobble i actually measured the inside off both tracks and it a couple of thousand but over the length of layshaft it was a wobble
Have you tried a breath testalanscottj wrote:My back wheel on me TS1 GP has a tiny bit of movement, a bit of a wobble. I have tried different hubs, cones, everything but can't get rid. The shaft itself is solid, gearbox all shimmed up proper. Any thought MUCH appreciated as it is doing my head in!
alanscottj
Breath test???ducksta wrote:Have you tried a breath testalanscottj wrote:My back wheel on me TS1 GP has a tiny bit of movement, a bit of a wobble. I have tried different hubs, cones, everything but can't get rid. The shaft itself is solid, gearbox all shimmed up proper. Any thought MUCH appreciated as it is doing my head in!
- Information
Who is online
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 6 guests
