Clutch / brake lever fixing bolt
Guys I'm after the bolt that fixes through the clutch lever it's part threaded I've fitted a master cyclinder in place of normal front brake and the original fixing isn't long enough . Supplied with kits is a longer fixing but I've got gold plated one I'd like to keep any ideas where I could purchase one from with a longer thread
mick1
- registered user
- Main scooter: Li Avanti 225
- Contact:
Bit confused ? is it the clutch side or the hydraulic brake side ? You say you've got a longer fixing which would work but want to keep the original (gold plated)........so what do you want ?
- garry inglis
- registered user
- Main scooter: ts1 230 and rb200
- Contact:
if you have one get it gold plated just take it to a jewler that does repaires they will do it for a small or large charge
I need to change the bolt that holds the lever in place that fits to the master cyclinder nissin type . As my original pivot bolts have been gold plated but the thread isn't long enough to fitmick1 wrote:Bit confused ? is it the clutch side or the hydraulic brake side ? You say you've got a longer fixing which would work but want to keep the original (gold plated)........so what do you want ?
10 inch Terror
- registered user
- Xbox live gamer tag: No.
- Playstation gamer tag: PLEASE!
- Main scooter: Lambretta LI Imola 185
- Contact:
Like this?
https://www.ebay.co.uk/itm/262454451711
10 inch Terror
- registered user
- Contact:
I'm just trying to establish if this is what he's after. If he is I'd try a breakers yard if I were him. £14 postageKnowledge wrote:A £2 bolt, and £14 postage. If this is the bolt, let's hope you can find a UK stockist.....
10 inch Terror
- registered user
- Contact:
Each to their own I suppose.
Yes same as what I'm after many thanks but as you say f joke on postage . yes all engine casing nuts etc also gold plated plus pike nuts and hub nuts all by previous owner all chrome work by quality chrome hull
- Information
Who is online
Users browsing this forum: Ahrefs [Bot], Google Adsense [Bot] and 5 guests
