Cracking to Rear Oil Seal housing - ADVICE Please
Strummer10
Hi Guys,
just 'gutting' a 200 indian GP engine casing and found the rear hub bearing/seal retaining plate is held on by 4 bolts (rather than the usual 4 studs and nuts seen on the Italian casings) which is an indian design I guess.
It looks like someone in the past has wound them down too far (or the nuts were too long) so they have marginally cracked the aluminium to the circle around where the rear hub bearing sits, but not through to the outer edge (ie; the side you see from within where the brake shoes sit) but you can, on 2 studs see the cracking on the internal face.
Any solutions, other than welding ? It only affects the two upper holes ?
Strummer10
Must stress the cracking is only where the two lowers screw threads are, not structural to the actual casing
mick1
Main scooter: Li Avanti 225
I had something similar and used JB Weld, been fixed for 2 years with no issues. Not a perfect repair but as far as i'm aware it's only to hold the oil seal retaining plate in place and there's not a great deal of stress.
Strummer10
Hi Mick, sorry was JB weld ?
Strummer10
OK, sorry just google it and found it.....'epoxy resin' . IF it's just to hold the oil seal in place then less worries I guess
    Users browsing this forum: Google [Bot] and 9 guests
