Vespa P200e top mph in each gear...
railfancwb
Here is what I [think] I know about the P200e engine/transmission/wheel:
Circumference of tire 52" measured
Per published specifications:
Stated engine 12 hp @ 5700 rpm
Stated top speed 65 mph
Engine to clutch 23/65
First gear 12/57
Second gear 13/42
Third gear 17/38
Fourth gear 21/35
Published specs came from:
http://www.scooterhelp.com/scooters/VSX1T.p200.html
Have been trying without success to go from this known information to top mph in each gear. Except for measuring circumference of the tire I have excluded my calculations and - probably - mistakes.
So... How should I make these calculations? And is 5700rpm the engine redline or merely its point of highest horsepower?
Thanks!
mick1
Main scooter: Li Avanti 225
You're close....... this link is from the same site, hope it helps:
http://www.scooterhelp.com/tuning/vespa.gear.calc.html
railfancwb
Thanks for the link!
It appears that my P200e is topping out about 4500 rpm.
Spanish Fly
Main scooter: P200e
Do you know for sure that it has a standard gearbox?
If a previous owner fitted a t5 4th gear it would lower your top speed.
SF
railfancwb
No, I don't know that the actual gears inside the case meet the published tooth counts. The scooter was running when I got it so no reason to split the case.
railfancwb
What are the possible combinations with the clutch output gear and the Christmas tree input gear? The P200e default appears to be 23/65. I've seen clutches on eBay with as few as 20 teeth on the cog, with 21 and 22 more common. Have not seen any with more than 23.
To maintain the 23/65 mesh seemingly would require 68, 67, and 66 teeth on the larger gear. Don't recall having seen any of those.
Jack221
Main scooter: PX221
It might be too early in the morning but what is your issue? If your p200 is just not fast enough, then you came to the right place :)
Vespa est ieiunas, quia semper operaturi
Ginch
Main scooter: Vespa 150 Super
This visual gear calculator is very handy for what you want to do.
http://gearingcalc.free.fr/
