Changing Spark Plug grade after Dyno
Want to chat about dyno result or any other aspect of graphs/power/components....then post here!
Angelo
I had my SS180 dyno's at Scooterotica last year and set up lovely. However it tends to foul plugs every now and then. Dan told me that it would be one of two things; either too much oil in the petrol or wrong spark plug grade.
If I was to change the spark plug grade now, would that mess up the setting that the dyno advised to run with?
mick1
Main scooter: Li Avanti 225
probably not. The dyno is good for checking power and torque, and also the timing/air/fuel mixture, etc. Changing the plug is more a "heat" issue which (and I may stand corrected) the Dyno doesn't usually check.
it's quite common for riders to change plugs to suit driving conditions (round town/motorway) without changing other settings.
Bofs
What plug is it?
Sent from my D5803 using Tapatalk
Muffspeed....no muff too tuff
Bad Samaritans SC
1957 Zundapp Betta 500 Auto
Angelo
An NGK B6ES is in now.. I was gonna change it to an NGK B7ES.
That will probably help
bazza3004
Is the B7 not a cooler running plug than the B6 ? If so would that not make the plug foul up more.
Donnie
it is but im a bit surprised a B6 is in in the first place!!
Donnie.
Donnie
Even more worrying when looking at a copy of the ss180 specs on Scooterhelp.com it specifies a bosch W240T2 which is not made anymore but when cross referenced is actually a B8es which is what I thought should be in there in the first place.
So hopefully, the owners eyesights at fault and has mistaken an 8 for a 6 :o
Donnie.
    Users browsing this forum: No registered users and 49 guests
