pathfinder spots
dave wheeler
anyone know how to get into the bulb area of pathfinder spots? seems to be a sealed unit, also anyone know where to get the chrome domed bolt that holds the reflector?
mine fell out
smoore-gt225
Main scooter: lambretta GT200
my pathfinders have a screw on the front st the bottom and the lens comes off
Rich
If I'm reading this correctly you want to get the reflector apart from the lens? Twist off the Bakelite bulb holder, take out the bulb. If you're lucky the reflector will just come away from the lens. If not it can be teased apart gently with something like a small screw driver but don't go mad or you'll chip the lens. Not sure if the remade ones are the same but shouldn't be too different. You might get the chrome nipples (hehehe...he said nipple) from somewhere like Holdens. If not its an ebay search I reckon :)
dave wheeler
thanks rich
dave wheeler
is the bulb holder just a push in then?
Rich
Yes mate, both the early Bakelite and later round plastic holders just push in and twist to line the tabs up to remove.
dave wheeler
cheers bruv
    Users browsing this forum: Semrush [Bot] and 26 guests
