Ts1-225, TMX35, SuperTourer. Jetting?
alanscottj
Have recently fitted Franspeed Tourer to my TS1, anyone got a similar set up? What jets are you using? Thanks.
TS1-225
TMX 35
Franspeed SuperTourer
Varitronic Ignition
GP200 gearing
Boreham
Main scooter: GP225
Hi, as a starting point
20.5 pilot
en56 needle, second clip
Main jet 310
alanscottj
Boreham wrote:Hi, as a starting point
20.5 pilot
Main jet 310
Thanks, not far off what I have:
57 second clip
310 main jet
Doesn't feel far out, plug could be a bit darker and cht is a bit higher than it was when I had the JL3 on at around 135f zipping around town :D
Toot-oasc
I have a Taffy exhaust on my TS1 225 & my TMX 35mm is set up as follows:
53 needle, 2nd clip
340 Main
20 Pilot
Run with 4% oil/petrol mix
I've been getting about 8 mile a litre (believe the carb was fairly new when I bought the bike in 2009 - since then I've done in excess of 25,000 miles). I've just purchased a brand new TMX35 and fitted a Robbospeed Road exhaust (both last night) and getting it dyno'd again this Wednesday but the starting point is as above.
Lots of people are surprised that I run a 53 needle, but it that means it's safe, I'm more than happy with it (any problems I've suffered on this engine have not been due to carb issues - dodgy crank, ring peg, worn piston circlip, engine mount snapped).
Toot-oasc
Hi
After the dyno yesterday, on both exhausts, the jetting in my TMX35 TS1 set up has remained exactly the same as posted above.
19.9 BHP in 3rd gear for the Robbospeed Road with peak power between 6,500 & 7,000 revs
20.1 BHP in 3rd for the Taffy with peak power around 6,000 revs
The Robbospeed will give higher revs and a greater top speed on the road (although not the 88.4 MPH that was achieved on the dyno :shock: :shock: )
Hopefully the miles per litre will be better with the new unworn carb?
mick1
Main scooter: Li Avanti 225
I run an Avanti 225 with a TMX
Pilot 25 (seems big but works on the Dyno')
57 needle top clip
290 main
Franspeed Race
breathsweet filter
23 on dyno
I think most TS1's run a larger main, 300+ with some running 360+
alanscottj
Thanks guys, I have the following:
56 second clip from top
310 main
Ok when I open her up but a bit jittery at up to 1/4 throttle, thinking it may need air mixture tweaking.?
Going to dyno soon but would like it to be run in a bit more :D
jonashford
Rb260, supertourer, tmx 35 22.5 pilot 57 needle 2nd clip down 330 main,
I have used 25 pilots and 350 main jets and down all successfully rich carbs are safer if u can run them.
roadrunnerian
I was running a tmx35 with franspeed supertourer with main jet 320/315 with 56 needle 2nd clip down I had it dynoed in the winter on a very cold day and it was 330 main with 55 needle
    Users browsing this forum: Google [Bot] and 10 guests
