Crank movement - explains the knocking!
alanscottj
For a few weeks now I have heard a knocking noise coming from engine, scooter not as smooth as she usually is and today she started to run a bitty boggy. Because she started to get a bit boggy I thought that the timing might be out so I took the flywheel off to have a look, the varitronic hasn't moved at all but the crank has movement, when I wiggle it (holding the shaft where the woodruff key is) I can feel it and hear it moving :roll:
So, I am assuming one of the bearings has gone, or could it be that the front sprocket bolt on the other side has come loose? Would that account for the wobble?
Which way is i moving in and out or up and down?
holty
Main scooter: lambretta gp
you should be able to turn the crank but you should not have any up and down or side to side movement, other thing to check for is any play between the piston and the crank, which would indicate big end or little end wear.
mick1
Main scooter: Li Avanti 225
It's all guess work till you split the engine apart.
The front sprocket shouldn't cause play on the crank. I'd be more looking at one of the bearings (mag or main) with an outside chance it could be the crank itself.
oily hands and a few curse words should get to the bottom of it...........
alanscottj
rosscla wrote:Which way is i moving in and out or up and down?
Both! In and out and I can wiggle it left/right! :roll:
alanscottj
mick1 wrote:It's all guess work till you split the engine apart.
Looks like it'll be getting opened tomorrow :lol:
Bearings are certainly knackered I'd say.
alanscottj
rosscla wrote:Bearings are certainly knackered I'd say.
Yeah, I thought as much. it's lucky I enjoy stripping and building engines :lol:
alanscottj
Stripped engine this morning. Looks like drive side bearing knackered :roll: to be honest when I spin the bearing with my fingers and try and move it it feels ok, no movement at all but with the crank in place, the cranks moves like this :
Click on image for video :D
HxPaul
To be honest,that looks pretty normal
    Users browsing this forum: No registered users and 25 guests
