self closing throttle
Timbo
Eden just curious to know when you last changed that cable....happened to me on the way back from France in a well lit and busy Slough High Street. It wasn't raining and several people helped out... :lol:
eden
Timbo wrote:Eden just curious to know when you last changed that cable....happened to me on the way back from France in a well lit and busy Slough High Street. It wasn't raining and several people helped out... :lol:
f@@k knows tbh. I know I recabled the GP not long ago so may have just got confused with the stress of it all lol
Swat
Main scooter: AF Rayspeed S type GP225
Happened to me on way to Whitby - only cable I didn't change during winter bike refresh. (sod's law) & of course the outer came away from its stop under headset so spare wheel off to get horncast off etc.. etc.. (Thankfully daylight but bloody freezing at 8am !) Gave the S type a damn good thrashing over the moors as punishment for it's insolence
Swat
As for the original question - I'm in the 'resistance' camp - Don't like the idea of being pitched over the handlebars cos the throttle snaps shut as you stick your right arm out to indicate (I'm old skool took test in '79 I still do quite a bit of arm indicating)
MIne also self closed on the way to Davos a couple of years ago when the throttle snapped. Easy fix in warm sunshine beside a German Autobahn but I didn't do the nipple up tight enough in the headset with the result that as soon as we encountered hills (Black Forest) the cable pulled through so that I was only getting 1/3rd throttle :shock: This was only really noticeable on the hills and became chronic on the ride up the mountain to Davos, flat out in 2nd at 25mph :oops: Naturally I didn't connect this with the change of throttle cable but assumed it to be altitude/jetting related :roll: I didn't find the problem until 2 weeks after I got back to the UK :? Amazing to find that my Avanti was still capable of over 60mph on the flat with only 1/3rd throttle.
Re the original question, I use an elastic band to stop the throttle closing as even with indicators it is still often necessary to use your right hand for additional signalling/acknowledging other road users.
diesel
coaster wrote:Re the original question, I use an elastic band to stop the throttle closing.
How do you do that?
jonzo172
Swat wrote:Happened to me on way to Whitby - only cable I didn't change during winter bike refresh. (sod's law) & of course the outer came away from its stop under headset so spare wheel off to get horncast off etc.. etc.. (Thankfully daylight but bloody freezing at 8am !) Gave the S type a damn good thrashing over the moors as punishment for it's insolence
I carry an old bike spoke with a hooked end to help pull the outer back into its stop... generally just a good little gizmo that takes up no room to carry.
Also good for threading internal gear cables on road "push" bikes too. :)
Just wind it around in the gap between the grip and the housing, they last a few months usually before disintegrating.
How do you do that?
eden
Swat wrote:As for the original question - I'm in the 'resistance' camp - Don't like the idea of being pitched over the handlebars cos the throttle snaps shut as you stick your right arm out to indicate (I'm old skool took test in '79 I still do quite a bit of arm indicating)
to avoid this situation if I need to take my right hand off the bars I pull the clutch with my left hand which stops you "being pitched over the handlebars" ;)
Snails
Minority wrote:Image
My "home brew" version
Can anyone help me with a picture of their set up with the spanish spring? Or describe how it should fit?
The images that Adam mentions in the post before this are long gone.
    Users browsing this forum: Google [Bot], Semrush [Bot] and 7 guests
