Lambretta sip rims
Ihateyoubutler
My sip tubeless rims with cont twist sport tyres hold air like a sieve. Anyone have a solution who has had the same problem? Is some sort of inner tube gloop the answer?
Thanks.
garry inglis
hi my mate had same bother they were leaking from the engraved numbers opposite the valve the engraving is to deep he took them back and got them changed and the new ones were fine I also use them on both my scoots and had no problem :D
All tuebless that I've run have needed tyres to be inflated above the standard 18/28 (or whatever the book says) and have found that you need them to be higher to seal correctly. I learnt this many moons ago when running ScootRS rims to Euro Lambretta, after initially having similar issues. Once inflated to a higher pressure they retained pressure perfectly. I've since found the same applies to SIP rims.
I RUN 20 I front and 30 in rear I check most weeks and noticed a 1-2 psi drop over a 2 month period i do use slime in mine
I run higher than that by about 5 psi in each, which may have a small effect on handling and wear but tyre pressure remains constant.
garry inglis
hi shocky I run the same as you but that's to carry my 15st arse lol////////
Chris in Margate
I have been using ScootRS tubeless for 6 years. 20 front and 32 rear. Anything higher definitely affects handling. Rear perfect; front about 1 psi in a month.
It would be worth putting the whole wheel in a barrel or the bath to see where the air is coming from, it could easily be the valve either the valve itself or the seal onto the rim.
I've thought of putting slime in my SIP rims but did note that the air hole in the rim is tiny (about 2mm)and I can envisage problems getting it in tbh :?
ForemanBob
Main scooter: GP RT230
coaster wrote:It would be worth putting the whole wheel in a barrel or the bath to see where the air is coming from, it could easily be the valve either the valve itself or the seal onto the rim.
To get the slime in I've found the easiest way is to deflate the tyre, knock the tyre off the bead and put the slime in the gap... Then re inflate.
ktmh5
Main scooter: GP225 Mugello
Never had any problem getting Punctureseal in Sip, AF 's or tubes TBH
Rich'
    Users browsing this forum: No registered users and 33 guests
