Toolbox Trim
I have a legshield toolbox and the door rattles. Ideally I think it needs a bit of trim around the lip to prevent vibration. What have people used to solve the problem?
bristolmod
shouldn't need any - bend the inner lock bit.
Scootering since 1968.
I might have too. :D
Fit Vespa toolbox buffers in the top corners
Norrie Bodge
Doom Patrol wrote:I have a legshield toolbox and the door rattles. Ideally I think it needs a bit of trim around the lip to prevent vibration. What have people used to solve the problem?
I did exactly as you thinking...
Got some door trim from Beedspeed, give them a buzz m8
Sent from my SM-G903F using Tapatalk
Shipleystevep
Jam a bit of cardboard in it
Minority
Main scooter: Li230 S3
Four little rubber buffers from the local hardware store, drilled and bolted one in each corner, Bob's your uncle!
(Guess it depends on what type of toolbox you have)
That's a good idea. Unfortunately it isn't one of them. Bristolmod seems to have come up trumps at the moment. A bit of jiggling of the lock seems to have tightened it up.
gaz_powell
this is what I use on frame/toolbox door and legshield toolbox door
http://www.ebay.co.uk/itm/201481150392? ... EBIDX%3AIT
    Users browsing this forum: Amazon [Bot] and 20 guests
