new cases
a.lo.v2
Main scooter: sx 200
getting exited with all these new casings being casted, but thinking, as you do, does anybody see any problems without having "matching" endplates?. what exactly are the two surfaces that are machined together? is it the cluster or the layshaft? or is it a case of anything will work with correct shimming? a lot of questions i know.
It's the layshaft holes
warts
Main scooter: honda
Modern CNC machining can ensure sufficient, repeatable, accuracy that "line boring" as in the old days is not required
ArmandTanzarian
warts wrote:Modern CNC machining can ensure sufficient, repeatable, accuracy that "line boring" as in the old days is not required
That only helps if both bits are made on modern machines. Do the new cases come with endplates or do they use the wibbly wobbly old ones?
warts
Main scooter: honda
You are absolutely right. Who would cut corners like that?
I wasn't thinking.
EddieStone
warts wrote:You are absolutely right. Who would cut corners like that?
SIL?
