Which dremmel?
alanscottj
Which is the best Dremmel to buy for doing the grinding, cutting and other fettling required with Lambretta parts? Mine has bitten the bullet and needs replacing but I can't find the same model again. What are you using? Tia :D
What model were you using? I suspect they might have discontinued the cordless version. I picked one up cheap quite recently.
10 inch Terror
Xbox live gamer tag: No.
I use a Black & Decker one. I've had it 5 years and it's still going strong. The attachments are readily available from B&Q, Screwfix etc etc.
alanscottj
Doom Patrol wrote:What model were you using? I suspect they might have discontinued the cordless version. I picked one up cheap quite recently.
395 mate. Not sure which one to get, the 3000 or 4000, just want to make sure the one I get is powerful enough.
Monty
I use the big boys dremmel a 5 inch angle grinder with a flap wheel. I spend more time changing cutting wheels or burs with a dremmel
bazza3004
found the 3000 more than enough for my needs. cutting porting etc.
Strummer10
I've got a dremel but when you depress the button to unlock the attachment your using it just turns so I can't get my bits out the end. Is there another Dremel with this button enhanced so it works better or is mine an isolated problem ?
Tractorman
bazza3004 wrote:found the 3000 more than enough for my needs. cutting porting etc.
Agree, could not manage without mine now.
Meds
Main scooter: Li125s
I use a normal drill with a flexible drive.
dansacred
Main scooter: li 150 series 3
    Users browsing this forum: Google [Bot] and 17 guests
