Oil/ petrol Mix
Tractorman
- Main scooter: Lambretta li150 special
What ever mix you decide on make sure your measuring jug is accurate because most are not.
Chris in Margate
- Main scooter: Lambretta 1964 225 Special
Oil from Auchan is a bolt on to the 250 bottles of wine.
- EddieStone
- Main scooter: Lambretta Li 150
Doesn't adding more oil make the mixture leaner because there's less fuel?a.j wrote:Oh, 3% semi synth around town, 4% on the motorway if riding to rallies.Chris in Margate wrote:6 litres of best available and a 1/4 inch short of 2 oil jugs (just under 200 mls. Approx 33:1
Semi synthetic from Auchan in France €9.50 for 2 litres. Less than £8.
Grumpy225
- Main scooter: Gori200, rt195, ld150,rb20
EddieStone wrote:Doesn't adding more oil make the mixture leaner because there's less fuel?a.j wrote:Oh, 3% semi synth around town, 4% on the motorway if riding to rallies.Chris in Margate wrote:6 litres of best available and a 1/4 inch short of 2 oil jugs (just under 200 mls. Approx 33:1
Short answer is yes.
Changing up oil mix ratios ot types of oil is ASKING to burn up a top end.
At the end of the day pick an oil, pick a ratio and stick with it.
I run 32:1 (3%) Yamahalube R every time from the first kick, on all types of top ends and I haven't seized a motor or holed a piston in close to 20 years.
- garry inglis
- Main scooter: ts1 230 and rb200
i use 4%
I also use 4%
Chris in Margate
I am of the opinion that adding extra oil for a longer journey could well induce the engine to run weaker and hotter.
It depends on who you talk too.
I used 3% Putolene Scootx in my standard 150 on advice from a dealer.
AF recommend 4% in their cylinders.
A work mate runs a competition trial bike and has dropped his rato from 4% to 2% fully synthetic on he advice of a Bultaco tuning guru, who recons modern oils are significantly better than the oils around when the bike was designed.
I have gone for 4% fully synthetic on the premis, oil is cheaper than bearings, thats what the designers of my cylinder recommend and if I screw up when fuelling then there is better than 3% in the tank.
- Adyonekenobi
- Main scooter: Li150 Special, now TS1 225cc
If you have 5 litres of petrol and add 2% oil mix then you have your 2% fuel oil mixture.
Adding more oil (say to 4%) to 5 litres of petrol surely does not make the mixture weaker, you still have 5 litres of petrol plus additional oil?
Spanner check the running gear before every outing, like in the Army. You know it makes sense!
mick1
- Main scooter: Li Avanti 225
Hmmmm.....No.
The ratio of oil to petrol has changed. When it mixes together there will be less petrol and more oil going into the carb/barrel....but the same amount of air......hence a leaner burn.............I think ?
