Rb Sprocket set up
Is your ignition all set up right?
sydduckett
yeah i presume so, anything specific to look for?
syd
bazman
sydduckett wrote:Have tried the 34 delly today and wasnt an improvement so i guess its either the sprocket se up or the box, 4th is still not there,even worse with the 34 so back on with the 30. People seem divided on the best sprocket set up so im a bit stuck for what to try next. Have a spare JL2 pipe im going to give a go to see if that makes any difference but i cant really keep trying pipes, so does anyone have any suggestions. Got an li150 box would a Li125 be any better as a mate has a spare i coulds try that?
Have now done the 600 miles so will drop it down top 3% but dont think that is going to change things much. also i feel theres no point in getting it jetted/dynoed yet as it feels like a gearing issue?
Any suugestion in order of lowest cost first appreciated..
As you were
syd
I'm with Al on this down to the exhaust try 5.0 ratio as that's where i'll be going when rebuilt :roll:
Also what's your jetting fella? You do know that the jl2 will need welding to suit the rb barrel....
On mine the franspeed race , struggles to pull 4th in adverse conditions but when in the power usually stays there but a bit all or nothing, type of kit i suppose :)
cheers Baz
p.s.
stick to 4% oil , when stripped mine down loads lovely golden oil deposits everywhere , and IF you ever have any issues with top end, they'll invaldidate warranty ;)
Train Driver
I have stuck to 2% on oil and used motul 800 or at a push 710 and no problems
bazman
6LDA 28B wrote:I have stuck to 2% on oil and used motul 800 or at a push 710 and no problems
Yes that as maybe , but if you want to keep your warranty ( or big end bearing ) intact , that's what they reccomend... ;)
red
When my last RB went belly up on me the other week I stripped it and everything was a nice golden colour from using Rock Oil Synth 2 at 4%,always run at that and will never change despite a comment from a 'reputable'dealer telling me that it's the worst oil going and he wouldn't even put it in a lawnmower :D
I've never had a problem regarding oil issues it's just everything else with me :(
I just wish that everything was as reliable as the oil
bazman
Very true Red !!
Not had much luck with my rb20 either, all parts at af the now waiting to hear there verdict.
sydduckett
Not sure what the problem is but will need to work it out, bit emabarrisinhg having an Rb that flies in 1,2 3rd but then tops out at 55... :(
suggestions for pipes that will fit an RB please, and yes the Jl will take some fettling....
sef
CPH Lambretta
Main scooter: DL 150 1970
The RB Franspeed race looks like the best on the market at the moment, the NK tourer looks like one of the worst.
Slow is the new fast!
sydduckett
Got a link for the franspeed..ta
syd
    Users browsing this forum: Semrush [Bot] and 22 guests
