Which carb for TS1?
dansacred
Main scooter: li 150 series 3
Yeah Hendy I do have the MB manifold that has the small "ears" (like you?) that i guess reduces the volume of the reed a bit but the "stuffers" reduce the volume a more than that...
hendy
Well, so far this has all been very interesting and informative to the extent that I've spent even more money (boyesen reeds) on my 50 year old shopping bike. However, I still don't feel like I'm any better advised as to which of the 3 carbs is the better option!
Darrell Taylor
Main scooter: LAMBRETTA
lozmondo wrote:Thats interesting re Imola reeds. I tried a 24mm Mikuni on an Imola with an RD reed fitted and it was hopeless...needed to put a 30mmPHBH on to achieve any sort of power...may reverse things
spot on..
hendy
I've been unable to track down an imola reed block /manifold.
Also, there are 2 versions; 48 and 52mm with 52 being the current version. I assume it's the early 48mm version that suits us?
All interesting stuff, my torquey tune TS1 225 is using an LTH short manifold with a 30 PHBH, anyone have any views on them? I'm fairly happy with my setup 58x110 crank, 2.5mm packer, Avanti head, Franspeerd Super Tourer. It does pull well albeit on 5.1 gearing (couldn't cope with 4.8) but maxes out at about 72mph (gps), won't rev much over 7.5k in 3rd :? Could this be the manifold??
