T 5 clutch
jonboy
Main scooter: Vespa T 5 Classic
My t 5 classic lurches forward when pulling away
Any ideas
ipman
They don't have a reverse gear if that's what your asking ;)
Toot-oasc
jonboy wrote:My t 5 classic lurches forward when pulling away
Any ideas
Is it used regularly? If not it could be the clutch plates sticking together, then releasing suddenly causing the 'lurch'.
Or, the plates could be worn and need replaced?
ducksta
new plates fresh oil fresh inner cable sorted soak plates overnight in a plastic bag i find best
ducksta
and check the turrets have no burrs on them
shamrockexpress
A big part of this problem is the springs being done, change plates and springs together preferably piaggio genuine parts.
Otherwise buy complete new clutch unit plug and play.
good luck
