anyone know of a british supplier of led bulbs for pathfinder lamps ...need a pair soon and can only find chinese that could take a while to come
ta phil
led bulbs
philcasino1973
- Main scooter: lambretta gp200
- coaster
The Chinese ones will be with you in about a week I would guess. I've ordered a fair few bits and pieces from China and have usually been amazed at the speed of delivery.
I'd be interested to hear how they perform, LED lamp technology has come on leaps and bounds.
philcasino1973
will order a pair and let you know how they are ...if they come before scooter is due to go to new owner
regards
phil
regards
phil
If they are anything like the the supposedly 80w headlight bulbs ...Don't Bother ...I expected so much more ....they are very white .....but not as good as a 35w halogen ...a disgruntled scooterist
- Monty
- Main scooter: Series 1 Muggy, Imola Special
Pathfinder uses a great pre focuses system so work great with a standard lamp giving a good beam. I have tried several LED type and have yet to find anything half as good. I'm using 6w Cree with a condenser type lens built in the front. It had several grooves cut round the aluminium lamp and I experimented how deep into the reflector the lamp sat. I made some small half moons to mount the lamp. It's not perfect but the light is very white so is akin to my HID headlight. The incandescent lamp was very yellow. For your mod types with lots of spots You van get Cree LEDS in most fittings that use minimal wattage
- coaster
If you tried it in a standard Lambretta headlamp Andy you were wasting your time as the reeded glass diffracts the light all over the place. The Jockey's headlamp uses a modern clear lens and a shaped reflector and should work much better with a modern LED lamp. That said, reviews I've read comparing halogen/LED/HID in the same light unit indicate that the HID is significantly better but the LED was better than the halogen and drew much less current....heat can be a problem with LED's though.afandy wrote:If they are anything like the the supposedly 80w headlight bulbs ...Don't Bother ...I expected so much more ....they are very white .....but not as good as a 35w halogen ...a disgruntled scooterist
mickymidas
- Main scooter: Vespa Rally /P200
Geezer in Old Bike Mart advertises led bulbs for all sorts of old bikes & scooters , might be worth a Google .
Think his name is Paul Goff , but ain't got a copy to hand at mo .
2Ronnies sc.......Chuckleism is the way forward
- wack 63
- Main scooter: '71 GP TS1
Go thru this site, seems to have all sorts http://www.norbsa02.freeuk.com/goffyleds.htm
Cheers Coaster for the explanation ...
- Information
Who is online
