flywheel pick-up alignment
shamrockexpress
Change my midweight AF flywheel to a midweight Scooter restorations one only to have hassle resetting the timeing until i looked closer at the fireing point marks on the SR flywheel
this is were the pick up marks line up to on the AF flywheel which runs fine and i,m sure is the correct position the only reason for changing is i,m trying to illiminate a vibration so trying a different flywheel
this is were the marks were lining up for the SR flywheel i reckon this is a way out.
this is the difference........
SR one on the left quality isnt great compared to the AF one right,
Has anyone else had any issues with the SR flywheel
gaz_powell
Mine was the opposite - I had a genuine sil stator and flywheel from sr that would not fire with the af light weight or mid weight. Same on another bike - geniune sil stator and flywheel that was on a complete engine from sr - af would not work. I'm sure if had persevered I couild have got it work. In the end I had both sr flywheels lightened and welded.
The joys of lambretta "compatible" parts
HxPaul
It might just be an optical illusion,but the AF flywheel looks like its got the woodruff key slot machined in the points position.
Muppet
window marks are a waste of time make your own tdc and timing marks on the mag then strobe
C’est la vie
jason frost
Muppet wrote:window marks are a waste of time make your own tdc and timing marks on the mag then strobe
New flywheel you will need to set new timing marks and check them with a timing light
shamrockexpress
Yes thats been done and scoot is running 100% as you can see in the pics new marks made from alignment of magnets.
can anyone clarify the firing point is the middle of the two finger plates?
Norrie Bodge
shamrockexpress wrote: can anyone clarify the firing point is the middle of the two finger plates?
Good point m8? Anyone confirm this ??
    Users browsing this forum: Ahrefs [Bot], Google [Bot] and 60 guests
