Mugello 200
mickeyb
Hi,has any1 ever fitted a Mikuni 35mm TMX to this piece of kit?
No, but I did post jetting for a TMX 30 which worked well on a Muggy 225 with JL3. Suspect a 35 would be overkill unless it's highly tuned.
mickeyb
Got a 30mil delly on it at the minute its very boggy when starting off like driving off slowly in 2nd gear in a car....will moving the clip up one help or wud a 24mil mikuni be better?....it was set up on a jl pipe before it was put on mine now with a clubman.
eibargum
Mine was boggy setting off [40 slide, 28mm phbh] so i took 0.5mm off the slide cutout to lean it off abit at the bottom end, worked a treat :D . I agree with Martin regards the tmx35mm, overkill.
giankx
I have got the muggy 200 with tm24 and it's a bit boggy too, i think is the wrong head compression so i bought a MB head.
Does anoyone tried it ?
    Users browsing this forum: Google [Bot], Semrush [Bot] and 10 guests
