sip speedo sensor
garry inglis
wack 63 that pic of your front set up should be in the tate gallery lol/////
Thank you but it's one I built for a mate.
wack 63 wrote:Thank you but it's one I built for a mate.
Nice neat cap to blank off the original speedo fitting. 8-)
I used an oil drain plug but have contenplated one ofthose new anodized alloy ones
Same here, just an oil drain plug.
Minority
Main scooter: Li230 S3
I got rid of mine.
thesx200
MB used to sell a bracket for the trailtech speedos which are similar to a SIP ,simple bracket that fitted on the axle on the near side of the disc , a lot more neater than the ones on show here.
ImageThe Trailtech one would be no good without being modified as it used a threaded sensor with two nuts
eden
smoore-gt225 wrote:I just did it like this in the end glued the magnet to the disc,
seems to work fine not got to worry about the cable anymore
[url=http://s481.photobucket.com/user/sjmoor ... 4.jpg.html]Image[/url
That's how I did mine. :)
I run on the cable now though on the sip because I use the magnet for my Gamma.
Sip speedo defo reads higher than the gamma!
cartmel808
If you use the active sensor do you still need to use a magnet for the pick-up?
    Users browsing this forum: Amazon [Bot], Google [Bot] and 3 guests
