Battery Just for Horn ?
DigDug
Yanker wrote:
lambro wrote: If you can live this is most of us do, just put a bulb horn on once a year for the MOT, they are allowed pre-1973 and that will sort things easily.
Shaun.
Nope: Must have a 'continuous' tone on the horn (flippin eck even Victor Meldrew knows that!) for the MOT (when was the last time you rode Lambro'[?)
The real answer in this situation is to turn up the tick over on the scooter to +/- 2000 rpm (or whenever the 'dimming' stops) and present it for MOT Tada!
Cheers
Light blue touch paper and retire. :shock:
Did you have to do that?
firekdp
Yanker wrote:Nope: Must have a 'continuous' tone on the horn (flippin eck even Victor Meldrew knows that!) for the MOT (when was the last time you rode Lambro'[?)
:lol: That only applies to machines first used after 1st August 1973.
HxPaul
Machines first used before 1st August 1973 can use a bulb horn.Press on link and scroll down the page for info.
http://www.bennetts.co.uk/bikesocial/ne ... s7Cr0CJazM
EddieStone
Recommend the 25W bulb. Bright enough light even at tickover. It's what originally specced for these
nellyboyo
Dargeln Motors in Morriston , Swansea , Dave, He does a lot of scooters for Dai at OSW ..which is about 500 yards away
ukpeckerwood
Main scooter: Vespa PX210
dave411 wrote:Where did you take it for MOT.Mine needs doing soon.
Take it to Fairwater garage and let Pete do it, does most off the scooters around the area, nice guy and gives you a discount too.
http://www.fairwatergarage.co.uk/
nellyboyo
Discount !!! :o
lambro
Shaun.
Cheers
If you don't mind stepping down from your high horse, and learn the facts before replying!
Bulb horn is perfectly accepatable pre-1973.
"An audible warning device is usually an electrical
horn. A horn is defined as an instrument, not being
a bell, gong or siren, capable of giving audible and
sufficient warning of the approach or position of a
vehicle.
A motor bicycle first used before 1 August 1973
may be fitted with a bulb horn. "
Shaun.
squeakmillward
dont remember the name of the garage but back in the day he used to sell you a bulb horn every year for the mot lol! Had them in just for Lambrettas
nellyboyo
Late update to this boys, did the job with a small-ish 12v2.5 A re-chargeable battery mounted in the toolbox and a DC horn and it really works well.
Miles better than the normal sqwark !
