small block kit advice
nellyboyo
I've got an imola and a long stroke mugello with a reed valve so I can only speak for these 2.
The imola is mental and mugello more bottom endy and smoother. I could go on ....... :D
Timbo
I would go for the RT, superbly engineered with plenty of potential for increased performance if you decide you want more from yor scoot..
Burnside
Main scooter: Lambretta TV200
002pg wrote:Thanks for the replies.
I am just after a standardish kit for a bit of a runaround, as I am in jersey its just for short trips 1 up, got standard gp200 gearing with 22mm carb and a mbbgm clubman. Don't really want to go reed valve or big carb as I also have an rb22, just want something to putt around on.
Casa 185 sounds ideal for this...personally I like the GT kits but maybe overkill for what you want?
Padge
Main scooter: 1969 Lambretta gp
Iv'e had a few good results using a GP 150 barrel bored to 62/64mm (175/186) play with inlet and exhaust timings but don't go too wild (140-145 inlet and 165-168 exhaust) flow/match transfer feeds 22mm carb, drilled airbox, final drive circa 5.2-5.4 and a clubman.
It will never set the tarmac alight but should havea lot more grunt throughout the rev range and doesn't hit a brick wall at 6,000 rpm
002pg
Thanks for the replies, I've decided to go for the rt kit and see what its like with the 22mm carb and maybe upgrade to a 25mm carb in the future.
garry inglis
ive just been on mb site and out of stock on rt195 kits I would ring them up for when the next batch is in
Try Scooter Centre in Cologne.
Padge
002pg wrote:Thanks for the replies, I've decided to go for the rt kit and see what its like with the 22mm carb and maybe upgrade to a 25mm carb in the future.
if your changing to a bigger carb but want to retain the original look I prefer a 24mm PWK on correct manifold, so original bellows, filter and drilled airbox can be used, cheaper,smaller and more compact, they run a lot smoother/cleaner low down, snappier throttle response and a doddle to jet in
    Users browsing this forum: Ahrefs [Bot], Google [Bot] and 4 guests
