TS1 Running Fast on Tickover
ktmh5
Main scooter: GP225 Mugello
My TS1 won't tickover and if I hold throttle very slightly open it races and four strokes. No air leaks and choke seating properly. Could damaged reed petals give these symptoms?
Rich'
Try cleaning the idle circuit out.
ktmh5
wack 63 wrote:Try cleaning the idle circuit out.
I have had the carb apart a dozen times or more so I think it is clean. That doesn't answer my question about yhe reed petals.
Whenever Ive had to repair reeds the motor won't start and tends to backfire. For piece of mind take the block out and inspect.
molibdimum
When was the last time you had it running right Rich and have you done anything to it since then?
Can you try another carb off one of your other scoots?
Whats your ignition set up?
ktmh5
molibdimum wrote:When was the last time you had it running right Rich and have you done anything to it since then?
Steve it's a new carb' and was running fine until dynoed!
Is the needle clip still on?
ktmh5
wack 63 wrote:Is the needle clip still on?
Certainly is, carb has been apart many times.
Is it a Throttle cable issue ?
ktmh5
Toddy wrote:Is it a Throttle cable issue ?
Pretty sure it isn't as the slide is opening and closing fully as it should. The only thing I can say is that the tickover screw doesn't seem to have any effect on the engine speed. I can only adjust the tickover with the outer cable. The revs don't come down quickly at all and when I do get it to tick over it just suddenly cuts out.
