pacemaker gearbox
garry inglis
just bought my new project a nice 1964 li150 silver special as original as you can get can some one tell me when they changed the week gearbox 3rd on these all I can find is early ones had a week 3rd thanks :D
bsso78
Are you leaving it standard
garry inglis
i am giving it a full nut and bolt resto as a true special but i have a nice af 175 iron kit from my other scoot and a25mm delorto af 42 box ithink that will be the only changes just to give it a bit more wumff i am going to take a lot of pics and i wil post some up
bristolmod
if its that original why bother doing a resto? As Coxy used to say- "they are only original once!"
Scootering since 1968.
ducksta
agree with chris leave it alone or treat it to a descent engine and upgrades brakes suspension etc
wack 63
Main scooter: '71 GP TS1
My '65 import had the thick 3rd gear but the earlier drilled cluster and as far as I could tell no one had been inside the motor,so it was either fitted in the factory or went to a service centre.
garry inglis
thanks wack63 when you say thicker by what 2 or3 mm I bet there is something in stickys bible :lol:
wack 63
The teeth on the loose 3rd gear are visibly thicker on the end compared to the other gears.
bsso78
ill come round and have a look at it
shamrockexpress
this is my 64 silver special, needs new seals and bearings looks like engine hasnt been opened still runs ok i,m keen to keep it totally original points and 6 volt............
would love to ride this one back to milan next year exactly as it left the factory :)
    Users browsing this forum: Ahrefs [Bot] and 24 guests
