BGM Clubman exhaust
Hotdog
Has anyone had problems fitting the down pipe to the exhaust ? how tight is to tight ? received mine today and i only just managed to join the two together after a lot of sweating and swearing and then the same again to pull them apart ! that can't be right can it ?
alanscottj
Mine was a nice fit but not near impossible :D
dennis
Main scooter: 1 gp 1 special
Yes, i think it distorts a little when you bolt it to the cylinder,I got some grinding paste (the stuff they used to grind car valves in with) and just spun it in until it went in nice,once this was done i then sealed it with silicone seal, bath stuff.
hendy
Mine was a sliding fit even though I've nickel plated it.
Couldn't have been better really. Good enough that I didn't use sealant but went on easy.
Grumpy225
If you are dry fitting the pieces they can gall together and be near impossible to take a part. Always use some sort of lube (especially with stainless parts).
My BGM V2 pipe fit perfect.
ulyssescale
I've had two version 2 BGM boxes that wouldn't mate together straight with the u-bend. Spewed all kind of s**t out of the joint. It was as if the u-bend was too short or needed to be bent.
A chicken ain't nothing but a bird.
kejj
I've fitted 2 and during winter service refitted them several times. Easiest exhaust I've worked with on a lambretta!
Yes darling,but is it art?
________________________
http://tv175.wordpress.com/
Timbo
I've fitted a few and the last one was very difficult, I think MB reccomended oil to get it on...
Just checked my PM's and MB reccomended grease but I used 3-1 oil and it worked a treat.
Hotdog
Might have to try grinding paste as Dennis said, plan was to have it chromed !
    Users browsing this forum: Majestic-12 [Bot] and 8 guests
