My Li150 S2
bigscottyuk
Main scooter: Vespa PX200
Doom Patrol wrote:I would. A better design.
Cheers. SH/18 be ok for standard 150cc set up?
It depends what you want from it, I suppose. A 20mm would be a good all rounder. But, depending on what your plans are I would think about a new 22mm carb from Scootopia. You'd have to use a larger manifold with that, but they are cheap as chips. At least you'd have a bit of leeway built in if you want to take it out to a 175 or similar at a later date.
bigscottyuk
Yeah I should have taken a picture before I stripped it...#confused
Too many bits. The later SH carbs are simpler and make working on them quite easy. It's a personal thing, but I don't see much point in anything beyond a 22mm.
