px longstroke 125cc
ducksta
Which kit runs best with a 60mm crank polini or malossi or pinasco
Juan
Parmakit TSV 187 or Polini Evo 187 seeing as both of them are designed for that to start with.
OzOAP
Main scooter: Vespa PTS1E
I have used P2 60mm cranks in 125s.
5mm longer rod and wider inlet web so port can be widened.
just need to fit different small end bearing to convert 16mm rod to 15mm pin. Wiseco do a Yamaha one thats spot on.
ipman
OzOAP wrote:I have used P2 60mm cranks in 125s.
Which kit?
OzOAP
Malossi 166.
guygrrr
Main scooter: 1980 Vespa P187
You'll see an improvement stroking any of those cylinders. But it's not as if one is better than other as the cylinders are designed to produce power differently.
I can only directly comment on the Malossi and Polini. The Malossi is a still a rev monster, if a bit less so and the Polini is quite a bit torquier.
At this point, if I'm swapping out a crank it's getting replaced with a stroker. Probably my favorite has been a Sprint V with a reworked, standard top end. It wasn't hugely powerful but it would pull from nothing like a stock bike never would, and was a delight to ride.
more can do, less doodoo.
