My Li150 S2
Grumpy225
bigscottyuk wrote:i still have no spark.
earth lead changed all good.
continuity checked on plug cap, ht lead & coil...all good.
assume problem is in stator.
pulling it tomorrow night to have a look.
If it's the 4 pole stator make sure the tail light bulb is working. If I remember the brake light grounds through the ignition coil.
bigscottyuk
Main scooter: Vespa PX200
Checked the rear light. Think it might not be standard
GeorgeS
It does look a little bespoke! You could just disconnect everything but the coil and try that to for a spark.
bigscottyuk
Popped the cover off the rectifier too...
Yeah think converting to electronic might be the way forward.
ArmandTanzarian
bigscottyuk wrote: Yeah think converting to electronic might be the way forward.
My series 2 had the original four pole electrics and although it was reliable, the lights were terrible. A faint orange glow at any speed other than flat out.
It didn't have a brake light either. Yours might have been the same, hence the extra bulb in the tail.
bigscottyuk
decision made.
BGM electronic ignition kit & new loom inbound...
bigscottyuk
Mmm bog standard dual seat? Can't
see any markings on it. Any ideas?
It's a strange one. I don't think it's original. Probably an after market pattern seat.
bigscottyuk
Carb removed & stripped last night. Looks like the MA19 BS7 carb from the design of the float.
Looks in good nick. Are these any good with a standard set up or is it worth upgrading with to a SH?
I would. A better design.
    Users browsing this forum: No registered users and 68 guests
