Li kill switch
Trekker si
Main scooter: Lambretta li
Is there any way of putting a key ignition switch instead of the kill switch?
garry inglis
all you do is buy your ac or dc ignition disconnect the kill switch and remove put the green off the new ignition into the same hole and connect the pink wire to earth and that's it just cut the rest off and tape up
Trekker si
Will I need to make the hole bigger or can you get smaller ignition,as it looks a smaller diameter?
garry inglis
no they fit ok you keep the part were the wires come out the back to the right hand side
garry inglis
only the small section off the ignition fits through the hole the bigger section with the rubber over it sits inside
Trekker si
Thanks I'll give it a go
Chris in Margate
You'll find it easier than you think.
hendy
I had to dremmel quite a lot of metal out of my li125 s3 headset to make room for the rubber covered part that goes inside the headset.
Wear glasses; I had to go to hospital to get a piece of aluminium out of my eye. Dope :oops:
Trekker si
It's looks like I'll need a bit dremmel as for for eyes been there , not nice
Donnie
aye, if its a series 3 li you will, series one and 2 theres enough room without dremelling.
I'd always question why you want one though personally i prefer the push button kill switch.
Donnie.
    Users browsing this forum: Amazon [Bot] and 8 guests
