Not another series 2 (update)
simon wrote:Corrado I got a 123 main jet, this seems to be what most people are running with a clubman, what do you think :|
That seems to be around what most would recommend. I was in Rayspeed so picked up a 120, 122, & 125 plus 45 & 48 pilots for you play with, you may want to start with the 125. Start rich and come down slowly is the safe bet. Anyway stay away from main jet for a few hundred miles. ;)
simon
Cheers 8-)
simon
A bit more done :P nightmare getting the horncover and front mudguard to line up :twisted:
markwh45
not long now mate and it will be finished looking very nice :D :D
simon
Made a new holder for the CDI and regulator, wanted to keep it as tidy as possible
Buttoned up the headset at last, all electrics tested and work :o
simon
Got problems with the rear runners, the kick-start side runner is touching the engine cowling, I will need to get the dremmel out :evil:
How much should I take off :?:
simon
Nearly done, just a few wee bits to go :)
nigesx200
wasn't really a fan of the s2 until now!! :shock: oh my god its stunning.well done mate,you are a very very lucky lad.
simon
Thanks for your kind words, it was worth all the hassle :D
simon
Got the dremmel out :shock: and cut the rear runner :shock: it was tight against the cowl and also rubbing against the exhaust bracket
After a bit of a touch up it’s as good as new ;)
