Wiseco Small end bearing
Fruitjuice
Building a Monza kit with a 71mm Wiseco piston 423M07100.
The piston didn't have the small end bearing when I got it.
What small end bearing do I need? The gudgeon pin is 16mm but the space between the lugs is wider then a standard Lambretta piston.
Also, where can I find a Lambretta 225 5mm base packer?
Life shouldn't be a journey to the grave with the intention of arriving safely in a pretty, well preserved body, but rather to skid in broadside, in a cloud of smoke, thoroughly used up, totally worn out, loudly proclaiming: "WOW, WHAT A RIDE"
Darrell taylor at taylor tuning google contact info
or Richard taylor on here
HxPaul
Fruitjuice wrote:Building a Monza kit with a 71mm Wiseco piston 423M07100.
INA do a standard Lambretta 16x20x20 small end bearing,you can get a 16x20x22 Japanese small end bearing.
jonashford
You don't normally get a small end with a piston
    Users browsing this forum: No registered users and 64 guests
