Over revving when hot - Ts1
yian-ts1
Running a slightly tuned ts1 225 with 35mm mikuni ,ram air filter and jl4 pipe, fine when cold but revs high when warm and when slowing down seems to oscilate??? Can't set tick over at all when hot? Any ideas?? To be honest looking for a starting point before i start to strip everything. Runs fine through rev range?
Cheers Gents
Yian
Sounds like an exhaust leak..?
tony
Main scooter: 90ss
Could be a few things that one. Could be lean and as motor heats up the effect is leaner hence the over revving.. or somewhere the motor is drawing in air. It could be from virtually anywhere. Head, base, seals, mag housing or even a crack somewhere.
Pilot jet too small, blocked or just requires setting the air/fuel screw??
jackpot
had the same problem but with a 34 dellorto turned out the filter in the carb was all clogged up,changed allsorts before i found the fault
ON MY SCOOT OR NOT AT ALL
mickeyb
Happened me last month after i refitted the carb.....tightened up the hose at the back of the Mikuni and hey presto....problem gone!
yian-ts1
Thanks gents
Will give it a strip down this week, check everything tight and no leaks
Thanks again
    Users browsing this forum: Majestic-12 [Bot] and 5 guests
