chroming carb body
oggy
Going two start blinging my chop and have seen some carbs chromed,but have heard some horror stories. Any body had it done . good???? :D
oldbiker
Never done it `cos I think it looks a bit naff.
If you like it go for it.
but remember some of the very small drilled holes may become blocked, also you will find many defects in the plating where it has not quite got into the corners etc.
oggy
fair point,but its very visible on my bike and with the rest nice and shiney the carb looks a tad dull :cry: any ideas.
eadmr04
I've heard of problems with chromed carbs before, can't remember what the problems where though. Could you not just have the ally polished, normally looks as good as chrome anyway :?:
nigesx200
i had a chrome carb a few years back,NEVER AGAIN. the bloody thing kept popping off its rubber mount. real pain in the arse :evil:
things like carbs don't chrome to well ,apart from the fact that they tend to have lots of angles ,holes and general knobbly bits that cant be polished easily,the chrome often wont get in to the corners as (correct me if I'm wrong) hydrogen gas is trapped in corners and this prevents the chrome from adhering
oldbiker
RICSPEED wrote:things like carbs don't chrome to well ,apart from the fact that they tend to have lots of angles ,holes and general knobbly bits that cant be polished easily,the chrome often wont get in to the corners as (correct me if I'm wrong) hydrogen gas is trapped in corners and this prevents the chrome from adhering
spot on mate, just like batterys give of gas during charging
GCSE chemistry
see your old text book and ref. Electrolocys (hope that`s spelt right)
oggy
ok i will think on it,cheers :)
Andy
Oggy, strip the carb down and dip it into a hot solution of phosphoric and nitric acid. Around 20-1 mix is fine.
Leave to soak fizz and bubble away for 5 mins and rinse. Wont come out like chrome but will give the ally that new look.
storkfoot
Andy wrote:Oggy, strip the carb down and dip it into a hot solution of phosphoric and nitric acid. Around 20-1 mix is fine.
Isn't the acid just eating away at the alloy of the the carb?
