Hey how you doing pal?... didn't realise that was you - good to see you've made a start with it.Grooveywordbender wrote:Yip very nice set up. Actually bought a set of GS forks from the guy who built that scoot in the link you enclosed...Graham (cartmel808), seen Sean Brady building his Quattriini too, last time I visited Dan and Sean.
Moto Vespa (GS) Project
cartmel808
- Main scooter: 1975 Vespa Rally 200 Femsa
Grooveywordbender
Hi Graham, hope your well mate. Yes slow going but taking my time and learning as I'm going along. Hope to get a bit more time in the hut this weekend and post a few photos.
Shaun.
Hi Gary,
Could you shed a wee bit more light on the GS rear wheel etc for alignment please. Have not sourced a donor engine yet and wondered if the engine type is impacting on a wheel selection....if that makes sense. Was under the impression I could simply plug in a P2 lump for instance? Have just took receipt of x3 Sip tubeless wheels and tyres???
Cheers Shaun.
Shaun.
Hi Gary,
Cheers Shaun.
cartmel808
You'll be fine with what you have there Shaun... Gary's scooter is a wide frame - whereas yours is a large frame.... I've done 3 motovespa 150s frames with p series motors, disc front ends & sip rims & and non have wheel alignment issues...
Grooveywordbender
Phew...you've just made my night. Cheers Graham.
Grooveywordbender
Little update on the progress. Trying to dry build as much as I possibly can. Sean build the engine for me as a mile muncher with plenty of torque for the country roads up here. Slow going but crimbo should see a bit of a shimmy on. Plan just now is Black.
Standard 200 Gearbox
Pinasco Flytech Ignition
Sip crank 200 case
Polini 210 Alloy kit with head
60mm long stroke 'bell' shaped crank - SeriePro
Malossi ReedValve kit
23 Tooth Cosa Clutch
SiP pipe
30mm PHBH Dellorto carb
Sip crank 200 case
SiP pipe
Grooveywordbender
Going for the all in-one tank and seat combo with a rear filler cap. Akin to the ones that scooter in style produce. It's with the fabricator now. Simple low profile in black.
Grooveywordbender
Ps. Had a shoofty at your wiring setup with the electronic kit and the GS switches etc on another site...going to have a dry run without power over Christmas. May need some pointers if I get stuck lol.
cartmel808
Looking good Shaun - I saw your new engine being built when I was down @ Shaun & Dan's a couple of weeks back... very nice!
Keep the pictures coming
