TS1-225 & which Carb to use ?
Norrie Bodge
All
I'm gonna fit a TS1-225 kit in the new year to my ongoing winter project
LI - Series 2
Iv already got a JL-3 pipe & fancy getting a dellorto 30mm flatslide?
Are these the type to go for?
http://www.dellorto.co.uk/shop/dellorto ... vhsh-30cs/
Cheers
holty
Main scooter: lambretta gp
when i bought my ts1 kit from ray, he recomended the 34mm dellorto, it was trimmed on a lathe to give pannel clearance, but the scooter ran much better with the pannel off so cut a hole in it.
:D
Norrie Bodge
Wont be cutting me panels m8?
hendy
What about a mikuni tmx30? Much cheaper than the dellorto you're looking at and I think gives good panel clearance.
What are people's views on these carbs?
The 30mm VHSH is a smaller carb that the 34 VHSB. I was very happy with a VHSA 32mm, which used to be Taffspeed's carb of choice, on an MB manifold. The carb mouth lip was machined back a little to clear with the initial standard TS1 manifold, which gave plenty of panel clearance with the MB item. The VHSH 30 is a very good carb and I have a number of mates running them on TS1s.
I also have pals running TMX Mikunis and they like those too.
Mr G in NYC
Main scooter: SX200
Adam_Winstone wrote:The 30mm VHSH is a smaller carb that the 34 VHSB. I was very happy with a VHSA 32mm, which used to be Taffspeed's carb of choice, on an MB manifold. The carb mouth lip was machined back a little to clear with the initial standard TS1 manifold, which gave plenty of panel clearance with the MB item. The VHSH 30 is a very good carb and I have a number of mates running them on TS1s.
+ one on the 35mm TMX . fantastic carb . G 8-)
Norrie Bodge
Thanks for reply Adam
Any chance of getting some jetting guides off ya mate please bud?
Thanks
gaz_powell
if you go dellorto flat or round 34 to 30 I`ll sort it for you - no problem
get the bits and give me a shout
G
