T5 stator problems?
Ilango
Main scooter: SIL Vijai Super
sleepinghorse wrote:After trying again, now getting over 1000 ohms from the pickup(red) and nothing from the LT (green). Looks like there might have been some "operator error" around the multimeter, earlier, sorry . So, once I've got a flywheel puller, I'll look at replacing the LT coil then, with Piaggio or BGM?
Hi Sleepinghorse,
It could be a case of loose or dry soldering too. You will have to remove the flywheel and check the coil resistance again.
-Ilango
    Users browsing this forum: No registered users and 71 guests
