more air through filter
scootcoot
Does anyone know how to turn a standard lammy airbox airfilter to let more air flow through ? (other mods have been done to the box inner cut out,holes in the box etc)
am a doogal r u a doogal too....!
Grumpy225
There are a few tricks to getting more air in.
Remove air scoop restrictor
remove air box bellow/bladder
drill holes or punch louvers in air box
run a high flow mesh filter
all of them work okay. Have to keep in mind that the stock air box was not meant to flow a lot of air.
I put a standard air filer/box set up on a flow bench to see what we could do to improve the flow. We found out that a lot of the flow restriction came from the elbow that connects to the rubber boot. In the end I just removed the whole box and ran a remote filter.
Try the BGM air filter. It's a wire mesh basically, and as far as I can tell very little restriction.
scootcoot
Many thanks for the advice ...
dennis
Main scooter: 1 gp 1 special
I've got the BGM filter which i cover with oil to help catch particles,i let it stand for a couple of hours after oiling.
HxPaul
If your not using a cheap Indian Steel Bird filter element,but an Italian one,try changing to the Indian one because they let more air in due to the fact that they have a covering of wire mesh,Italian filters have a covering of steel drilled with holes and they are a lot more restrictive.
barnsleybilly
Main scooter: Li200
If you really need a drastic increase in air then I'm with Grumpy225.
Better fitting a small foam filter directly onto the carb than trying to overcome all the other bottlenecks.
    Users browsing this forum: Baidu [Spider], Google [Bot] and 3 guests
