Issue with Rapido
whonatic
Cheers everyone
eden
Chris in Margate wrote:Try another CDI first
and/or a stator. ;)
I do leak down tests with the piston at BDC so that the ports are all open.
whonatic
and/or a stator. ;)
Cheers for that :D
Yanker
The inlet is closed! :cry: FFS?
hendy
Mine isn't. Ffs
Yanker
hendy wrote: Mine isn't. Ffs
Go on then: How do you thoroughly 'leak down test' that? Yes with the inlet open and the manifold plugged FFS ;)
OP says it's got a reed valve and DT250 piston. If that has an inlet window then bdc would be fine I think
eden
LOL, jesus you must run a tight piston to bore clearance. ;)
Try reading all of a topic before letting your fingers type, Clown!
FFS
Scooterotica court is now in session ;)
EddieStone
Is the air vent in the fuel tank cap blocked? Either that or the coil could be malfunctioning when it gets hot.
