Clutch Advice
tippo88
I'm putting a Scootrs Atomic clutch in my S3 Li, am also fitting a cleaned up SR185 kit and intention is to be a reliable fun ride for my wife not a racer
Couple of questions, I have all the bits to go 6 plate but are there any pros and cons vs going with 5?
Secondly the scootrs "c" clip is way beefier than the original and difficult to fit, is it worth persevering to fit it or go with the less beefy original?
Thanks in advance.
Cheers
Tippo
HxPaul
I've got a series 2 with a Casa 210 top end and a series 3 with a Casa 185 top end,both run on standard 4 plate clutches and I've never had a problem with either and they're both easy on the hand.
The clutch seems overkill I use a 4 plate in a 5 plate crownwheel with a 4 plate inner and a deeper outer I have alot of seperation not sure what spings I have I did have a jl4 and 30 mm carb on with a harry barlow stg 4 gp 200 gearbox never had any slippage ,I guess with more plates you can have standard springs which might suit a lady , id use the thicker circlip it might just need filing down a bit on the open end good luck ;)
