tight manifold
scooterslag
just putting together a engine and using a stock 20mm delly and manifold which I bought from separate sources, problem being is the manifold is way too large to insert (oh er... :D ) into the carb body, any decent tricks or tips to get the buggers to fit without knackering anything? cheers Paul
The mack daddy on the left!
Chris in Margate
You've probably been sold a 22mm manifold. Dremmel and emery paper I'm afraid.
You could sit watching TV whilst rotating the manifold in s sheet of emery paper.
scooterslag
Chris in Margate wrote:You've probably been sold a 22mm manifold. Dremmel and emery paper I'm afraid.
Nope its the right manifold Chris 19.41.1004, its just bloody tight, yep was going to go the emery cloth route, just wanted to see if there was a easier way (lazy git) oh the 20mm is off a serveta while the manifold is italian, don't know if this makes any difference.cheers Paul :D
bristolmod
shouldn't make any difference if the parts are genuine- my thoughts are that the manifold is a remade item possibly?
Scootering since 1968.
scooterslag
bristolmod wrote:shouldn't make any difference if the parts are genuine- my thoughts are that the manifold is a remade item possibly?
Hello Chris, the manifold in innocenti stamped, it may be a remade item but looks pretty authentic to me, just have to start rubbing it down I guess, thanks for the replies, Paul
bristolmod
even the remades state "innocenti" - Looks like a rub down with emery. Should be OK IDC- it only needs to9 be a fraction oversize to cause problems.
bazza3004
Once rebuilt a Li 150 motor and grabbed a manifold out of another box of 150 bits and this was way to big to fit the carb on. When i checked the manifold id fitted was off a indian GP150 and was as i say a larger od than the Li 150 one.
bazza3004 wrote:Once rebuilt a Li 150 motor and grabbed a manifold out of another box of 150 bits and this was way to big to fit the carb on. When i checked the manifold id fitted was off a indian GP150 and was as i say a larger od than the Li 150 one.
Possibly for the Mikcarb that was fitted to some of them?
bazza3004
Hi I did check the carb that was also in the box id got the manifold from and it was a jetex were as the Li one was the standard delly . cheers. baz.
