small block to large block conversion
golf19gt
Main scooter: lambretta ts1 230
has anyone had there small block cases convereted to take a large block by oiltek if so your thoughts or does anyone else do it
dapper
I know Digger on here had a case done. Looked very well machined. They can add more meat around the transfers for tuning too. But you'll have to be patient as they're turnaround is quite long at the moment apparently.
Agent Buchwald
Nice video on youtube of it being done - I would link to it but I've just described it as a video so you probably got a handle on my tech abilities.
golf19gt wrote:has anyone had there small block cases convereted to take a large block by oiltek if so your thoughts or does anyone else do it
Yes sent one in august still waiting :| and the price keeps creeping up
DigDug
As Dapper said I've had two done.
First one about 3 years ago - a Series 1, fast turnaround, had the 6mm studs taken out 2 8mm and it was vapour blasted.
Second one this year Spanish LIS took about 5 months, wasn't cleaned and generally doesn't look as good a job.
I've met Paul and had a cuppa with him when I dropped it off. He's a good bloke just maxed out with work I reckon..
Did you have to do that?
CS Engineering in Norwich (Chris Sadd) does this work. His method is old school by hand but he is seriously good. He converted an Indian GP 150 engine for me including repairing several broken studs and stripped threads and turned it round in about 3 weeks. Nice guy too 8-)
golf19gt
ok thanks for the reply,s
roadrunnerian
my mate had one done on his small block hes well chuffed with the job by oiltek but said it did take a long time, a couple of lads I know rate oiltek highly but reckon it depends on how many he gets in I know on cnc machining its cheaper to do long runs of jobs its the setting up, programming etc that is time consuming, Mike from Denton near manchester does it as well but I think he does it by a different way
I PERSONALLY wouldn't even consider it, a GT186 or an RB 20 will meet 99% of peoples requirements. The work required plus a 200 top end will cost as much as a GT186 and an Indian 200 won't be a match for a GT kit and to get better performance than an RB20 you're going to have to fit another decent kit on your new 200 casing. All imo.
DigDug
corrado wrote:I PERSONALLY wouldn't even consider it, a GT186 or an RB 20 will meet 99% of peoples requirements. The work required plus a 200 top end will cost as much as a GT186 and an Indian 200 won't be a match for a GT kit and to get better performance than an RB20 you're going to have to fit another decent kit on your new 200 casing. All imo.
I'm the 1% Martin..... ;)
