Gearing - best ratio?
alanscottj
What would be a good sprocket set up for the following:
Mugello 186
Li 150 pacemaker
I have a 47 clutch sprocket and a range of front sprockets - an 18 gives me 4.8 in fourth - would this be a good set up?
Many thanks in advance :D
mick1
Main scooter: Li Avanti 225
Your choice of exhaust will be a major factor..........
cgt75b
Main scooter: lambretta
Yes it should pull that gearing with a clubman exhaust though.
Best of luck.
handofdave
Main scooter: li ts1
personally i would go for 17 and 4th will still be quite tall on hills
dave
alanscottj
What would be the best ration for a JL3?
Tractorman
I felt my Pacemaker with the same kit and BGM exhaust was geared too low so I put a standard 150 box in and it pulls well in top with more speed but you do notice more sluggish acceleration but you can't have everything.
kejj
I went for 4,98 with 46-17 on my pacemaker box with a RT195 and MBGM CLubman. It gives me enough of both worlds regarding speed and acceleration in town.
________________________
http://tv175.wordpress.com/
alanscottj
Thanks for replies. I have managed to get a 46t clutch sprocket, what are recommendations for the front sprocket with this???
roadrunnerian
Hi m8 a lad I know had a mugello 180 kit with Li 150 box he had 15x46 sprockets which I thought was just right with a a/f 42mm box exhaust, he was advised to try a 16 x46 but he sold it before it was fitted
Shipleystevep
I run a mugello 186 Li 150 box 16/46 sprocket with bgm clubman and 30 mm delorto.
It's a superb ride
