GT big block experiance : New GT crank info added
Rich_T
Main scooter: Li Special
start of Jan 2016....definitely. They are producing 25 cranks per day, about 150 completed so far, order is for 500pcs. I'll post some pics up of the production so far.
Does the casing need trenched for the 62?
eden
Richard would be best answering that as the case I put mine in already had the trench taken out for previous cranks that I have ran in that case.
Rich_T
rosscla wrote:Does the casing need trenched for the 62?
It only needs the lightest of touches. The 60 stroke goes straight in, the 62 would require 1mm removing to give same clearance as the 60 stroke. You might get away with 0.5mm
Thanks for the response Rich.
eden
Fired up another new GT250 for the 1st time the other day. :D
A few test runs this weekend and if all is well it's owner will be out and about on it soon.
garry inglis
after spending the week reading all 43 pages of this brilliant topic and edens videos and lessons I think back to 1974 at thirteen messing with my first li150 all you had for advice were the older lads who had got you interested in the first place and in darlington were iam from there was no scooter shop we had to go to lens at Shipley anyway what iam getting at is all we do now is press a couple off buttens and you can all the advice you want on new products ,were from, and ,how mutch plus the crack is great by the way I have just fit a rt195 (nicasali) mb clubman and 30mm I will let you no how I get on
slangen
Main scooter: TV200
slangen
Main scooter: TV200
Received a Franspeed race snail, will be using this on my GT200 when it arrives but will try it out for fitment on the gt186 tonight. If only the bloody snow could go away.
dave411
Main scooter: Li 125
Does the exhaust exit to the front?
